125
Changing the Default Selected Cell Value for a Decimal Column
I am trying to change the default Selected Cell Value from 0.00000 to 0 or 1. The column type is decimal. How do I do that when using UltraGrid.
  • 469350
    Suggested Answer
    What do you mean by "default selected value?"
    The value of a cell comes from the data source. So if you have a column in the grid and you want it to default to a certain value, you would have to set the value on the data source. Or, if this is an unbound column, you could use the DefaultCellValue property on the column.
