635
UltraWinGrid exception while adding items to its databound list
Hello all,
I've got an UltraWinGrid that's data-bound to a BindingSource:
bindingSource.DataSource = new List<MyDataObject>();
ultraGrid1.DataSource = bindingSource;
After I add (866) items to the list using a background worker thread:
foreach (var item in itemsList)
 bindingSource.DataSource.Add(item);
I get the exception below. It doesn't happen with any consistency. Sometimes it works just fine. Any ideas what's going on?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Destination array was not long enough. Check destIndex and length, and the array's lower bounds.
   at System.Array.Copy(Array sourceArray, Int32 sourceIndex, Array destinationArray, Int32 destinationIndex, Int32 length, Boolean reliable)
   at Infragistics.Shared.SparseArray.CopyToHelper(Node n, Array array, Int32& index)
   at Infragistics.Shared.SparseArray.CopyTo(Array array, Int32 index, ICreateItemCallback callback)
   at Infragistics.Shared.SparseArray.ToArray(Type type)
   at Infragistics.Win.UltraWinGrid.RowsCollection.RowsSparseArray.ToArray(Boolean create, Boolean syncWithSortedSparseArray, Boolean dontFireInitializeRowOnNewRows)
   at Infragistics.Win.UltraWinGrid.RowsCollection.InitNonGroupByRows(IList fireInitializeRowOnTheseRows)
   at Infragistics.Win.UltraWinGrid.RowsCollection.SyncRowsHelper(IList boundList)
   at Infragistics.Win.UltraWinGrid.RowsCollection.SyncRows()
   at Infragistics.Win.UltraWinGrid.RowsCollection.VerifyGroupByVersionHelper()
   at Infragistics.Win.UltraWinGrid.UltraGridRow.get_ParentRow()
   at Infragistics.Win.UltraWinGrid.UltraGridRow.get_HiddenResolved()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.get_FirstRow()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.GetMaxScrollPosition(Boolean scrollToFill)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.EnsureScrollRegionFilled(Boolean calledFromRegenerateVisibleRows)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.PositionScrollbar(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.ScrollRegionBase.SetOriginAndExtent(Int32 origin, Int32 extent)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.SetOriginAndExtent(Int32 origin, Int32 extent)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.ResizeRowScrollRegions()
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UltraWinGrid.DataAreaUIElement.set_Rect(Rectangle value)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.PositionChildElements()
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SmartSignal.Com.EPICenter.Joust.UI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Com.EPICenter.Joust.UI.exe
SmartSignal.Service.Contract
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Service.Contract.DLL
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SmartSignal.Com.EPICenter.Joust.Core
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Com.EPICenter.Joust.Core.DLL
SmartSignal.Client.Helper
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Client.Helper.DLL
log4net
    Assembly Version: 1.2.10.0
    Win32 Version: 1.2.10.0
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/log4net.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.1 built by: SP
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
SmartSignal.Common
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Common.DLL
SmartSignal.Client.Tray
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Client.Tray.EXE
System.Runtime.Serialization
    Win32 Version: 3.0.4506.2152 (SP.030729-0100)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
SMDiagnostics
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
SmartSignal.Client.Control
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Client.Control.DLL
SmartSignal.Service.Common
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Service.Common.DLL
Infragistics2.Win.v8.3
    Assembly Version: 8.3.20083.1009
    Win32 Version: 8.3.20083.1009
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Win.v8.3.dll
Infragistics2.Win.UltraWinTabControl.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabControl.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabControl.v8.3.dll
Infragistics2.Shared.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Shared.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Shared.v8.3.dll
SmartSignal.Com.EPICenter.Joust.Data
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Com.EPICenter.Joust.Data.DLL
SmartSignal.Com.EPICenter.Joust.Controls
    CodeBase: file:///C:/DevSSC/SmartSignal/Main/source/Projects/Joust/bin/SmartSignal.Com.EPICenter.Joust.Controls.DLL
System.ServiceModel
    Win32 Version: 3.0.4506.2254 (QFE.030729-1900)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.IdentityModel
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.IdentityModel/3.0.0.0__b77a5c561934e089/System.IdentityModel.dll
System.Web
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.WorkflowServices
    Win32 Version: 3.5.594.1152
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.WorkflowServices/3.5.0.0__31bf3856ad364e35/System.WorkflowServices.dll
System.ServiceModel.Web
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel.Web/3.5.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
Microsoft.VisualStudio.Diagnostics.ServiceModelSink
    Win32 Version: 9.0.21022.8
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualStudio.Diagnostics.ServiceModelSink/3.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Diagnostics.ServiceModelSink.dll
System.IdentityModel.Selectors
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.IdentityModel.Selectors/3.0.0.0__b77a5c561934e089/System.IdentityModel.Selectors.dll
Infragistics2.Win.UltraWinDock.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDock.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDock.v8.3.dll
Infragistics2.Win.UltraWinTree.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTree.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTree.v8.3.dll
Infragistics2.Win.Misc.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.Misc.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v8.3.dll
Infragistics2.Win.UltraWinEditors.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v8.3.dll
Infragistics2.Win.UltraWinGrid.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v8.3.dll
Infragistics2.Win.UltraWinGrid.ExcelExport.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.ExcelExport.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.ExcelExport.v8.3.dll
Infragistics2.Excel.v8.3
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Infragistics2.Excel.v8.3/8.3.20083.1009__7dd5c3163f2cd0cb/Infragistics2.Excel.v8.3.dll
System.Design
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
