95
Does UltraCalendarInfo allow any sort of searching?
I'm loading appointment data from a number of different sources into an UltraCalendarInfo control, and I need to locate the next open timeslot of a particular size given the workday settings and the appointments loaded. I can do this by-hand if necessary, but since I am already loading all of this information into the UltraCalendarInfo control it seemed reasonable to ask if there is already a function or feature of the control which does something similar. I didn't see anything that looked likely in the documentation. Ideally, I would like to search through only the visible owners but that would just be a convenience thing. If there is not a full-on search capability, is it possible to pick a timeslot myself and query the UltraCalendarInfo control to see if it is open, and if so, would only the visible owners be taken into account?
Any help is appreciated,
- Bret
  • 69832
    Suggested Answer
    Yes; use the UltraCalendarInfo.GetAppointmentsInRange method. If no appointments exist in the subset returned by the method, that slot has no appointments. You can pass an arry of the Owners that you want to consider to filter out the ones that you don't.
