I am doing some formating in my InitializeRow event.
I am checking the e.ReInitialize argument to test if it is a re-initialize or not.
When I perform a grid print using UltraGridPrintDocument the InitializeRow event fires and I test the e.ReInitialize argument. It is false.
Shouldn't it be true here?
I don't want to reformat all that data again.
Does anyone have a similar issue?
-duane
KDuaneS said: Yes, I am speaking of the Intellisense List. The FilterComparisionOperator.Equals does not exist. I can type it in and it does work, but it is not in the intellisense. I am running version 20081.2161 ONLY. That is what is in my References. I had to uninstall all previous versions to get 2161 to install. There are no other versions installed on this machine. Is there any other place I should be looking to determine if the FilterComparisionOperator has multiple definitions? But we also have a second machine here running 20081.2150 and the .Equals does not exist on it either. It is possible that is was missing from the IG installs.
I just tested this out again, but this time in VB, and I get the same problem. My guess is that VB considers the word "Equals" some kind of keyword or it is getting confused because of the Equals method on an object.
So it looks like this is a bug or a quirk in VB.
KDuaneS said:Could you explain what the MATCH operator does (for future reference)?
All of the operators are documented in the help.
Hey Mike,
I understand about the class working now because it is ignoring the .match operator.
I appreciate your patience.
Hi Duane,
KDuaneS said:I went ahead and tried it anyway and it worked. Any reason why it is not in the list, yet it is accepted?
To what list are you referring? The Intellisense list in Visual Studio shows all of the enum values for me, including Equals. If it's not showing up on yours, then something is wrong on your machine or your installation of Visual Studio. Maybe there are multiple definitions of FilterComparisionOperator in your project or something.
KDuaneS said: Well, "Match" worked in the class i built, so I thought it should have worked in the other code too. That is really confusing and frustrating to me when code will work in one place and not in another. I don't like guessing until I find something that works. It takes too much time I appreciate your time helping me find something so simple.
Match works in the class you built because the operator is completely irrelevant in the class you built. You are overriding the MeetsCriteria method and only returning true when the values are equal. The operator in that case is provided so that you can use it if you want to, but your code is basically ignoring it and performing an Equals comparison on the value.
I thought the same thing, but it is not in the list. I thought that strange.
Perhaps I am misunderstanding the issue here. But it looks to me like you should be using Equals instead of Match.
