315
Databinding and Memory Leak
Create a custom class, and define a collection for it i.e. BindingList(Of CustomClass). Initialize this and keep it in a vb.net module
On a form,  lets call it Form1, put a Grid on it and in Form Load set the datasource to the CustomCollection in the module. On Form 1 also put a button, onclick on which Form2 is opened
Create another form, Form2, there also put a Grid and in Form Load set the datasource to the same Custom Collection in the module.
Now open Form1:
click on the button - this will open Form2, in the load of which grid.datasource = customcollection gets executed. Then close Form2 without doing anything else on it. Repeat this step a few times. You will notice that after each button click the time taken to open Form2, keeps increasing progressively.
I have tested the same on a WIndows DataGrid, it works fine. Repeated clicks on the button in Form1, opens up Form2 right away without any delay
Can you suggest what might be going on
