Question on UltraGrid Events:-
I would like to paste a copied value into a particular ultragrid cell. I could do this using "DoubleClickCell" event but I'm looking for a single click. Could you suggest me which event I should use to achieve this?
I tried "BeforeCellActivate", and "AfterCellActivate" but it cannot be raised if that cell is already active.
The latest version is NetAdvantage 2009 Vol 1.
Although we try very hard to avoid it, there is always the chance of breakage when upgrading. I recommend that if you do upgrade, you also get the latest service release, since there are some known issues in the volume release build that are already fixed.
I currently use "NetAdvantage for .NET 2007 Vol. 3 CLR 2.0". What is the latest version I could use. Also, are there any known issues if I upgrade my grid to latest versions?
Thank you
The latest version if the grid has a ClickCell event. If that event does not exist on your grid, then you might want to consider updating.
Or, you could determine which cell was clicked on in the MouseUp or MouseDown event using UIElements: HOWTO:UltraWinGrid Mouse Position and Cell Identification
