I'm new to Infragistics. Is it possible to do Line Charting directly from an XML file that has a DataSet (.xsd) or must I use DataTables? All examples I have seen only use DataTables, is it possible straight from the DataSet. I am trying to plot the following relationship were each ID can have multiple XY values for any number of IDs. For example...
ID X_Value Y_Value
0 3874.10 834.64
0 3762.15 834.28
0 3181.25 637.01
1 764 634.12
1 764 629.15
1 764 524.15
1 721.5 475.51
if you assign the chart's DataSource to a DataSet, it will just use theDataSet.Tables[0] to get the data. or, if the DataMember is set to the name of a specific table in that DataSet, it will use that one.
with your data, you probably want a ScatterChart with these settings:
ScatterChart.ConnectWithLines = true
ScatterChart.UseGroupByColumn = true
ScatterChart.GroupByColumn = 0
ScatterChart.ColumnX = 1
ScatterChart.ColumnY = 2
