55
Multi row selection in multi band UltraWinGrid
I wonder how I can do multi row selection in multi band UltraWinGrid. It looks like it is possible to select multi rows in the same band but I want to do it across different bands. My grid has hierarchical tree structure.
Thank you in advance.
  • 4555
    Suggested Answer
    Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
    It is not supported through the UI. The only way is to do it programmatically.
    Magued
  • 1590
    Hi, Unfortunately, this is not supported by Infragistics.
    see
    http://forums.infragistics.com/forums/p/7036/29121.aspx#29121
    for more detaials.
    Alex
