Sorry but I've searched the ngs and haven't found an answer to something that should be intuitive. I have the following scenario:
UltraCombo bound to a table of values
UltraGrid bound to a Sql SP with a parameter
I want the combo's value to feed the parameter and have the grid update.
TIA - Mike
Hello Maharajan,
You could see a sample regarding this in our 'Windows Forms Feature Browser'.
If you have this installed(if you have marked 'Samples' when installing Net Advantage), you could run it from 'Start Menu' -> 'All Programs' -> 'Infragistics' -> 'Windows Forms' -> 'Samples' -> 'Samples (local)'.
When it loads, please navigate to the 'Grids' tab => 'WinGrid' and then 'Launch' the 'Samples Explorer' sample. Or you can type in the 'Search:' "' Samples Explorer '".
There please navigate to 'V3 Per Cell ValueList and Editors' sample and take a look at it.
Please do not hesitate to contact me if you need any additional assistance.
Sorry for Late reply.
What i am trying to do is i want to set value for ultra combo in ultra grid (this means one of the column contains ultra combo in each row) based on another column`s value in that same row.How can we do this ?
(Sorry if i am confusing you all)
Thanks in advance.
Maharajan
Hello maharajanmca2010,
Could you please clarify what is your goal with this? Are you trying to set a value in the combo based on the value in the current cell or at least this is what I am getting from your post as your requirement.
I'm not sure what you are asking. Can you explain in more detail? This might help:
HOWTO:What is the best way to place a DropDown list in a grid cell?
I have added ultra combo in a ultra grid. Each row of ultragrid contains FundingSourceID(This is one of the column). What i just want to do is, i Need to set the Ultra Combo value or selected row based on this FundingSourceID. How can i do this ?
