1176
exit row edit mode
hi i have a wingrid where checking a check box on a column i specified if row it's going to be copied to another table but when i check the row for copy stays the row on edit mode so when i press the copy button copy everything excepts the last row i mark for copy, im using the next code to exit the row from edit mode but something and the most importnat part is missing
please help
Private Sub dgvMissingCategories_MouseUp(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles dgvMissingCategories.MouseUp
' Declare and retrieve a reference to the UIElement
Dim aUIElement As UIElement = Me.dgvMissingCategories.DisplayLayout.UIElement.ElementFromPoint(New Point(e.X, e.Y))
' Declare and retrieve a reference to the Cell
End If End If
End Sub
If Not aCell Is Nothing Then
If aCell.IsInEditMode Then
'aCell.() exit edit mode ????Dim aCell As UltraGridCell = aUIElement.GetContext(GetType (UltraGridCell))
' If a cell was found display the band and column key
  • 469350
    Suggested Answer
    You can call grid.UpdateData to commit the changes to the current row.
  • 3565
    Verified Answer
    You could try setting the gird UpdateMode to OnCellChangeOrLostFocus. I had to do something similar for a project I'm working on because the users wanted to see the updates immediately after each column change instead of waiting until the row lost focus.
