270
Client-only Framework subset and Infragistics
I'm trying to build a Visual Studio 2007 C# app with the Client-only Framework subset 3.5 option checked in the project properties, Application Tab.
I'm receiving compiler warnings such as the following:
Warning 2 The referenced assembly "Infragistics2.Win.UltraWinGrid.v9.1, Version=9.1.20091.1000, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=MSIL" has a dependency on "System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which is not listed as part of the "Client" TargetFrameworkSubset. If this dependent reference is required, you may get compilation errors.
Can you remove the dependencies to System.Web so developers can use Infragistics with the smaller .NET Framework subset?
Best regards.
