315
Cell Button and Right Click Issue
I have added a Cell Button in one of the Grids. I perform some action on the left click on it. But the CellButtonClick event also fires on Right click of the mouse. I want to avoid this. Can any one please suggest something simple.
Hemesh
  • 37774
    Suggested Answer
    Hemesh,
    Unfortunately, the Click event that is triggered doesn't really let you know which mouse button that was pressed, only that the control was clicked.  Fortunately, since a Click event is really just a MouseDown followed by a MouseUp, you could keep track of this yourself in the MouseUp on whether to ignore the Click or not:
    private MouseButtons lastMouseButtons;
    private void ultraGrid1_ClickCellButton(object sender, Infragistics.Win.UltraWinGrid.CellEventArgs e)
        if (this.lastMouseButtons == MouseButtons.Left)
            // Process the click
            string s = "BL";
    private void ultraGrid1_MouseUp(object sender, MouseEventArgs e)
        this.lastMouseButtons = e.Button;
    You should also take a look at this KB article in case you want to determine which UIElement the user has clicked on:
    HOWTO:Taking action when right-clicking the WinGrid
    Sometimes simply checking the grid.DisplayLayout.UIElement.LastElementEntered is enough as well.
    -Matt
  • 3565
    Suggested Answer
    I was thinking if you had a reference to the editor control in the cell and captured the click event you could effectively pass a message to your button click event to tell it whether or not to execute the code. I don't think there are any event parameters passed in the button click event that will tell you what mouse button was used when the user clicked on it.
  • 3565
    Are you using an editor control for the column?
