365
Adding a Check Box to the column Header
i have added a dynamic check box column by using the following code.
Me
.gvUserManagment.DisplayLayout.Bands(0).Columns.Add("Delete", "Select")
Me.gvUserManagment.DisplayLayout.Bands(0).Columns("Delete").DataType = GetType(Boolean)
Me.gvUserManagment.DisplayLayout.Bands(0).Columns("Delete").Style = UltraWinGrid.ColumnStyle.CheckBox
now i want to add a checkbox to the column header.
could you please help me????
actually there is some code on the below link ,but i can't download or view it
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=4883
how to capture the column header checkbox event after adding the check box to the column header i.e
if we select the column header checkbox then all rows check boxes should be selected and vice-versa
