425
Problem with column width after setting hierarchical binding list
Normal 0 21 false false false DE X-NONE X-NONE MicrosoftInternetExplorer4
I am setting a hierarchical binding list as data source to my grid. After data binding, the first column cannot be resized. See my following code and screen hot. The problem is the sub binding list. Without the sub binding list all works fine. Setting the column width was ignored from the grid.
        public Form1()
            InitializeComponent();
            ultraGrid1.DisplayLayout.AutoFitStyle = Infragistics.Win.UltraWinGrid.AutoFitStyle.None;
            ultraGrid1.DisplayLayout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.RowSelect;
            BindingList<DocumentInfo> documentInfoList = new BindingList<DocumentInfo>();
            DocumentInfo documentInfo = new DocumentInfo();
            documentInfo.Identifier = "123";
            documentInfo.Name = "First";
            documentInfoList.Add(documentInfo);
            ultraGrid1.DataSource = documentInfoList;
            ultraGrid1.DataBind();
ultraGrid1.DisplayLayout.Bands[0].Columns["Identifier"].Width = 200;
        private class DocumentInfo
            private string mIdentifier;
            public string Identifier
                get { return mIdentifier; }
                set { mIdentifier = value; }
            private string mName;
            public string Name
                get { return mName; }
                set { mName = value; }
            private BindingList<DocumentInfo> mSubDocumentList;
            public BindingList<DocumentInfo> SubDocumentList
                get { return mSubDocumentList; }
                set { mSubDocumentList = value; }
