155
Child list for field TableName cannot be created
I have a windows application. When I select option one from a combo-box, I bind an UltraGrid control to a DataSet with to DataTables (Maestro and Detalle) and a Relation between them:
    ds_MaestroDetalle.Relations.Add(
                    "Maestro_Detalle",
                    ds_MaestroDetalle.Tables["Maestro"].Columns["ID"],
                    ds_MaestroDetalle.Tables["Detalle"].Columns["ID"]);
Since I want to Export to Excel the info in the two DataTables and the relationship, I use SetDataBindings:
    this.ug_Reportes.SetDataBinding(ds_MaestroDetalle, "Maestro");
Then, when I select option two from the same combo-box, I bind the same
Ultragrid to a DataTable.
    dt_MyTable.TableName = "Maestro";
    this.ug_Reportes.DataSource = dt_MyTable;
I get following message binding to the second option:  "Child list for field Maestro cannot be created."
I guess, when binding to the DataTable in the second option, UltraGrid is currently looking for Table Maestro in the DataSet (first option).
I try to UltraGrid.DataBindings.Clear(), UltraGrid.DataSource = null, but I don't know how to reset UltraGrid to start binding again without problems.
Thanks in advanced!
  • 10
    I have exactly the same problem. Hope somebody knows how to handle it. Please let me know if you solve it. Thanks,
