Hello everyone,
I am having a little problem setting the image of a tab back to (none) when using the Ultra Tab Collection Editor.
Initially I set an image for each tab, but now I decided I want to take it away, but unfortunately I can't.The Editor shows me the new "empty" image but doesn't enable the OK Button.Once I select another image the OK Button is enabled. Can anyone help me get rid of this image without having it to do in the code.
Thomas
By the way I am using the latest version
Спасибо Боря!
Hello Thomas,
What you could do is to click in the right field next to the ‘Image’ property in the designer window and press the ‘Delete’ key. This will ‘remove’ the image set before and it is not of a matter if you have selected the text in the right field or have not done this.
Please do not hesitate to ask if something comes up.
