I have Wingrid and have added a UltraComboEditor is one of the cells. I need to display the line patterns in dropdown for which the following code is workin fin
For Each de As DictionaryEntry In supportedLineStyles
Dim lineStyleKeyValue As DictionaryEntry = CType(de.Value, DictionaryEntry)
infraItem =
infraItem.DisplayText =
infraItem.DataValue =
App.ImageHAlign = HAlign.Left
infraItem.Appearance = App
ucmbShape.Items.Add(infraItem)
Next
Issue
App =
App.Image = GetImage(
1: ucmbShape.text = selectedItem And when I do mouse over a tooltip appears, Is there any way to hide the tooltip.
2: In the dropdown, the images size is reduced and a grey background is visible (refer to GreyBackground)
However if i add the same control with same code directly on WinForms, it works fine.
Why does the same control behave in different manner?
SHipra
Hi Shipra,
The code you posted here is unreadable. Probably because you copied from something that uses a clipboard format the forums don't understand.
So I'm afraid I don't understand what you are asking. Can you copy the code into NotePad and copy from there to clean it up? Or surround it with a 'code' block.
