I'm implementing drag and drop reordering of rows in my UltraGrid by changing the order of the items in my grids datasource, which is a BindingList<T>.
My code correctly manages the order of items in the BindingList, but the grid does not reflect that order.
Any ideas as to what I'm doing wrong?
jb
Actually, I didn't implement it according to that article, which moves actual UltraGridRow instances. I implemented it by reordering the model instances in my BindingList that the grid is bound to.
Turns out I needed to call UltraGrid.DataBind() to get the grid to correctly realize that I reordered the BindingList.
Thanks for replying though.
What's the process that you're using to handle the drag/drop reordering of the rows? Are you using a process similar to the following article?
HOWTO:How to drag and drop rows in a single WinGrid
I did a test of manually reordering the BindingList that a grid is bound to and the grid was correctly picking up these notifications, so if you could post a small sample project, or at least a basic description, it would help me track down where your problem is.
-Matt
