395
Automatic column sizing
I have an issue with autosizing of UltraTree.
I have object with several properties bound to DataSource of some bindingSource. This binding source is bound to DataSource of UltraTree. In design mode I made all properties but one invisible. The tree generates just fine and looks simple:
- Text
     - Text
     - Text
- Text
When I use ViewStyle as Outlook Express and set:
ColumnSettings.AutoFitColumns = AutoFitColumns.ResizeAllColumns
the Tree looks as I expect and its width is expanded to parent Control.
Problem is with ViewStyle = Grid.
The tree is generated ok, but the width of the column is set to some default value. I could not find any property that says to column in node to expand so all text in cells are shown to the user.
Anyway I found some samples how to fix it with:
UltraTreeNodeColumn.PerformAutoResize();
And here comes the problem:
Now my tree looks fine, shows even longer texts, but also it shows Label. So I set:
UltraTreeColumnSet.LabelPosition = NodeLayoutLabelPosition.None;
And with this all resizing is gone. I was trying to set up various properties with various values but with no success.
Is there a way to do automatic column sizing in UltraTree with ViewStyle=Grid and no Labels displayed?
