Hi.
Is it possible for me as a user to change the column names/titles while the application is running. Something like a rename/edit feature. And if yes, can these updated column names be persisted (maybe in xml file or resource) so that they can be reused when the application starts again.
Appreciate your help.
Thanks.
Hello, Generally you can chose which information want to save to that XML but, you don’t have possibility to chose all the properties you have set in the grid. You can use PropertyCategories enumeration on order to set the categories you want to save , and I believe you can use “Bands”, since I suppose you are not using UnboundCoumns. You can find more information here :http://help.infragistics.com/Help/NetAdvantage/WinForms/2009.1/CLR2.0/html%5CInfragistics2.Win.UltraWinGrid.v9.1~Infragistics.Win.UltraWinGrid.PropertyCategories.htmland http://help.infragistics.com/Help/NetAdvantage/WinForms/2009.1/CLR2.0/html/Infragistics2.Win.UltraWinGrid.v9.1~Infragistics.Win.UltraWinGrid.UltraGridLayout~SaveAsXml(Stream,PropertyCategories).htmlI hope this information was helpful.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
Thanks Dimi. That was helpful. Can you also please let me know how I can save just the caption and column order information using SaveXML. Which Property I need to use? I dont wish to save all the parameters in the layout.
Hello, Yes you can change the column name runtime using the caption property of the column you want to rename:this.ultraGrid1.DisplayLayout.Bands[0].Columns[0].Header.Caption. = "Test"; And yes you can use Save Layouts - SaveAsXml and Load Layout - LopadFormXml in order to get the changes that you make in your grid. And when you run you application and load the saved layout, the changes will be appear in the grid.See more details here:http://help.infragistics.com/Help/NetAdvantage/WinForms/2009.1/CLR2.0/html%5CWinGrid_Save_and_Load_a_Layout_to_a_File.htmlI hope this is helpful.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
