40
UltraWinGrid and BindingSource and RaiseListChangedEvents
Hi, I'm not seeing the UltraWinGrid with a datasource set to a .net BindingSource honor the RaiseListChangedEvents = false.  Can you give me some guidance on this ?
We are using a list<t> that implements ITypedList and we set the grid's datasource to the bindingsource and then the bindingsource.datasource = my list.
We do not want the WInGrid to update its contents when the underlying data source changes.  If I set the bindingsource.RaiseListChangeEvents = false, the grid is still updating the cell contents via the ITYpedList get PropertyDescriiptor.GetObject().  I am forced to return the real object that has been updated and I thought the grid will preseve the original values if I turned off the raiselistchangedevents.
Hoping there is a minor change we can make.
thanks
