250
a few questions
1) I have an UltraDockManager, and I want to have several tabs in it, either directly in the main DockAreaPane, or in DockableGroupPane.  I would like the tabs to show at the top of the pane rather than the bottom.  Is there any way to set this?
2) Is there any way to hide the caption/header area of each tab in the pane?
3) Is there any way to make the tab container, either the DockAreaPane or DockableGroupPane fill the container, such that is autosizes to the window.  Should I just do this by setting the size of the container programmatically when a resize occurs?
Fyi, I would like to have dockable tabs that act more or less like standard tabs by default, but can be dragged into their own dockable area if the users wants.
  • 440
    Question 2  This probably is not what you want since you lose your pin and close options, but this is how you do it.
    DockableGroupPane dgpTemplate = new DockableGroupPane();
    dgpTemplate.DefaultPaneSettings.ShowCaption = Infragistics.Win.DefaultableBoolean.False;
  • 440
    Suggested Answer
    To answer question one
    DockAreaPane dapTop = new DockAreaPane(DockedLocation.DockedTop);
    A full example.
    SuspendLayout();
                DockableControlPane dcpProject = new DockableControlPane("1", "Customer - Site - Project", this.controlFilterProjects1);
                DockableGroupPane dgpProject = new DockableGroupPane();
                dgpProject.ChildPaneStyle = ChildPaneStyle.TabGroup;
                dgpProject.Panes.Add(dcpProject);
                dapTop.Panes.Add(dgpProject);
                dapTop.Size = new Size(0, this.Height);
                dcpProject.FlyoutSize = new Size(0, 150);
                dcpProject.MinimumSize = new Size(0, 150);
                dcpProject.MaximumSize = new Size(0, 150);
                this.ultraDockManager1.DockAreas.Add(dapTop);
                ResumeLayout();
