405
Consistent column widths
I have a grid with multiple child bands, and I am having troubles keeping the coloumns lined up.  For the first couple of bands it works fine, and the column widths not only lock together, but when I adjust one of them, the other is automatically adjusted as well.  THe problem is, with my last band (4), it is not have the same behavior.  The columns do not line up by default, and when I adjust a column in band 2 or three it has ne effect on the columns in band 4.  Please see the attached screen shot for more info.
Thanks, Shane
  • 469350
    Suggested Answer
    Hi Shane,
    My guess is that the bands that do not line up are using RowLayouts. check the UseRowLayout or RowLayoutStyle (depending on what version you are using) on the bands that are not synchronized.
