hi,
I have a problem of adjust the column size to fit the data if the column also has the CharacterCasing to Upper.
It will cut of the length, my guess is the grid treat the autoresize based on original data without casing.
How can i get around it ?
thanks
caspers said:my guess is the grid treat the autoresize based on original data without casing
If that's happening, it's a bug and needs to be fixed. What version of the controls are you using? Make sure you have the latest service release: How to get the latest service release - Infragistics Community
If that does not help, please let me know and I will look into it further.
