20
Using UltraFormattedTextEditor as an UltraGridColumn EditorControl
i added an UltraFormattedTextEditor as an EditorControl to an UltraGridColumn, with its TreatValueAs = FormattedText. However, when I launch the application, an exception shows up and says "Object reference not set to an instance of an object"
at Infragistics.Win.FormattedLinkLabel.SectionUIElement.get_ShouldDrawBackColor()
what did i miss to cause that?
it works with treatValueAs = Auto, but that doesn't work well for me
thanks
  • 5118
    What is the type for the column you are attaching the UltraFormattedTextEditor to?
    What are some actual values for the column in question?
