I have 2 bands - band 0 being a regular row and band 1 is a card view.
I want to hide a column in band 1 based on another column in band 1. In other words, for each row in band 0, band 1 will have different number of visible columns. Is this possible?
When I tried to set a column's Hidden property to false, it merely disabled the column - not invisible.
You would have to use a Data Source that stores values as objects, such as a DataTable or UltraDataSource, or your own custom data source.
Nevermind - height seems to be read-only.
So I can set string type cell to null but what do I do if the cell type is an enum for example?
Is it also possible to set the Height of the cell to 0 for the same effect?
If I do set it 0, how might I reset it to the default height?
You can't hide a column on a row-by-row basis.
However, you might be able to acheive what you want using CardSettings.CardStyle = VariableHeight. In this style, null value cells are not displayed in the card. So you could set the Value of the cell to null to hide it.
