394
Get Value of Editor when IsValid is False
I would like to get the current Text entered in a Grid cell when the Editor's IsValid property is returning False.
I am inheriting the UltraTextEditor and I want to retrieve the current text entered during Edit mode from the Editor. I am using the current code to shadow the Text property so that if an Editor is passed in then rather than retrieving the Text property from the base UltraTextEditor, I want to get the current value from pvEditor. If pvEditor.IsValid is returning False then the exception is thrown telling me I cannot get Value. Is there a way to get the text that is causing the IsValid to fail? I can get TextLength, but no string :o(
    Private Shadows Property Text(ByVal pvEditor As Infragistics.Win.EmbeddableEditorBase) As String
        Get
            Dim currentText As String = MyBase.Text
            ' If this control is used as an Editor, then it means the Text property
            ' is not set.
            If pvEditor IsNot Nothing _
             AndAlso pvEditor.IsValid Then
                currentText = CStr(pvEditor.Value)
            End If
            Return currentText
        End Get
        Set(ByVal value As String)
            MyBase.Text = value
            ' is not used.
            If pvEditor IsNot Nothing Then
                pvEditor.Value = value
            End If
        End Set
    End Property
