1176
adding images to explorer bar items
hi to all
im trying to add images to my explorer bar items but im not able and dont know why
this is my code
 Private Sub LoadExplorerBarData()
        Dim DTTask, DTSubTask As New DataTable
        Dim x, s As Integer
        ExplorerBar.ImageListLarge = ImageList1
        ExplorerBar.ImageListSmall = ImageList1
        DTTask = CostPlanning.Conn.GetData("SELECT DISTINCT TASK_NAME FROM TBL_TRAFIC_CONTROL ")
        If DTTask.Rows.Count > 0 Then
            For x = 0 To DTTask.Rows.Count - 1
                'tscbDepartment.Items.Add(DT.Rows(x).Item(0))
                ExplorerBar.Groups.Add(DTTask.Rows(x).Item(0), DTTask.Rows(x).Item(0))
                '----------------------------------------------------------------------------- Fill subtask
                DTSubTask = CostPlanning.Conn.GetData("SELECT  SubTask FROM TBL_TRAFIC_CONTROL WHERE TASK_NAME = '" + DTTask.Rows(x).Item(0) + "'")
                If DTSubTask.Rows.Count > 0 Then
                    For s = 0 To DTSubTask.Rows.Count - 1
                        ExplorerBar.Groups(x).Items.Add(DTSubTask.Rows(s).Item(0), DTSubTask.Rows(s).Item(0))
                        With ExplorerBar.Groups(x).Items(s).Settings.AppearancesLarge.ActiveAppearance
                            .ImageHAlign = Infragistics.Win.HAlign.Left
                            .ImageVAlign = Infragistics.Win.VAlign.Middle
                            .Image = ImageList1.Images("Task")
                        End With
                    Next
                End If
            Next
        End If
    End Sub
any idea?, Thanks.
  • 69832
    Verified Answer
    Instead of assigning the image to the items's Settings.AppearancesLarge.ActiveAppearance.Image property, assign it to the Settings.AppearancesLarge.Appearance.Image property, or Settings.AppearancesSmall.Appearance.Image, depending on the item style.
