hi
i am using unltra grid bound with a data source but i want to place a check box column in the end
of every row means last column shoud be a check box , how can i do that ?
regards.
Using the grid designer you can add an unbound column to the win grid and set it's data type to boolean. If you are using a data table as the data source you could add field at the end as a boolean data type.
