855
Howto: Change PageOrientation
How to change the page orientation within the same section as in, Page 1 (Portrait), Page 2 (Portrait), Page 3 (Landscape), Page 4 (Portrait).
If I need different sections to do this, how do I continue the page number sequence across more than one section?
  • 469350
    Suggested Answer
    No, you have to use a separate section for each orientation.
    This is the default. If the page numbers are starting over, then you must be setting Continue on the PageNumbering to false.
