492
Fixed Rows scroll issue
   I am using NetAdvantage 2009. In my ultrawingrid there are only 15 visible rows, above that it will have scroll.  If i pin 15 rows in the grid, i can no longer see or pin any more rows in the grid even the grid has scroll. but it has to allow more number of rows has to be pin. The same thing applicable for column pinning also. This scenario is easy to reproduce using infragistics sample "V5.2 Fixed Rows Feature". It is very urgent requirement for me. Any other solution to fix this issue.
  Micky
  • 469350
    Suggested Answer
    Hi Micky,
    If the fixed rows fill the entire area of the grid, then there is no room for any unfixed rows to display and so scrolling will do nothing.
    There is no way around this, other than to make sure the grid is taller than the total number of fixed rows.
