I am experiencing some weird behaviour in Infragistics, when copying cell's using the AllowMultiCellOperations setting on an UltraGrid.
It seems that both Ctrl+C and Ctrl+Shift+C trigger the copy behaviour. Since we want to use Ctrl+Shift+C to do something else, is there a way to work around this?
We are using Infragistics v7.2 with all the hotfixes installed.
Great stuff, thanks Mike!
kevinmeiresonne said:is there a way to work around this?
Yes.
All keyboard interaction in the grid is handled by the KeyActionMappings collection on the grid.
If you loop through this collection, you will find a mapping for the letter "C" with the SpecialKeysRequired set to Ctrl.
There's a property on the mapping called SpecialKeysDisallowed and it's just set to Alt. So what you need to do is change the SpecialKeysDisallowed to Alt or Shift.
foreach (KeyActionMappingBase kam in this.ultraGrid1.KeyActionMappings) { if (kam.KeyCode == Keys.C && kam.SpecialKeysRequired == SpecialKeys.Ctrl) { kam.SpecialKeysDisallowed = SpecialKeys.Alt | SpecialKeys.Shift; } }
