890
How can I determine the datasource of a Band?
Hi All,
If I were to bind a grid to a BindingList(Of MyListItemClass), each column "maps" to a property of MyListItemClass.
During runtime, given a column, I can always get to the underlying MyListItemClass property and its value.
However, if one of the properties of MyListItemClass is a BindingList(Of MyOtherListItemClass), then that property does not map to a column, but maps to a "Band".
During runtime, given a Band, I *cannot* seem get to the underlying MyListItemClass property and its value.
My question is:  given a Band, how do I determine the object it is bound to?
Scott Pearce
  • 469350
    Suggested Answer
    Hi Scott,
    Actually, a band is a column. If you check the parent band's Columns collection, you will find a column that represents the child band.So I think you can do row.Cells["Child Band Name"].Value to get the actual BindingList property on the parent object.
    If I am wrong and that doesn't work, then an alternate way to get it would be to use row.ListObject property. The ListObject returns the row in the underlying data source that the grid row is getting it's data from. So if you have a parent grid row, you can get it's ListObject, cast it into a MyListItemClass, and access the properties of the MyListItemClass directly.
