125
Step-line chart and multiple lines
how can I display mutiple lines on a step-line chart?
I would like to show the variations of two different values over the same time scale (purchases and sales of a particular item). I built a DataTable from my database, which has time values on the first column and data values on the other two columns, but when I create a step line chart, only the second column is taken into consideration (purchases column).
How can I make it work? Should I initialize a composite chart?
The final result should be something like this:
http://www.advsofteng.com/images/stepline.png
Edit:
I tried to set up my chart as a composite chart through code, as explained in infragistics documentation and splitted purchases and sales in 2 different datatables, but without succes. I can only see an empty chart with an Y axis vith values between -1 and 1
