570
About UltraGridExcelExporter
When the UltraGrid's data is beyond Excel's max row,  if I used UltraGridExcelExporter control Export UltraGrid's data, it whether have error?  If it has problem, how can I resolve?  Please help me.
  • 12773
    The MS Excel 2007 support big amount of data. In order to implement it in your project you need to use xlsx format when you export your grid. See this code snipped:
    string fileName = Path.Combine(Path.GetDirectoryName(Application.ExecutablePath), "x.xlsx");
    this.ultraGridExcelExporter1.Export(this.ultraGrid1, fileName, Infragistics.Excel.WorkbookFormat.Excel2007);
    Also you need to get the latest service release in order to avoid this restrictions.
    Let me know if this helps.
    Sincerely,
    Dimi
    Developer Support Engineer
    Infragistics, Inc.
