463
ultraGrid Column
Hi
I am using grid header style is CheckBox. when my form is load then it is check.how i am setting it to as a uncheck at a  form load.when i click on
it it works as bacis nature ?
  • 6158
    Suggested Answer
    To change the CheckState of the header checkbox when it is initially displayed, you will have to call the SetHeaderCheckedState() method on the column itself. This can be done in the the InitilizeLayout event handler:
    e.Layout.Bands[0].Columns[0].SetHeaderCheckedState(this.ultraGrid1.Rows, true);
    Note that we are currently investigating an issue where CheckStates that are set prior to the form being shown are lost when the HeaderCheckBoxSynchronization resolved to 'None'.
    If you require further assistance regarding this method, please let me know.
    Chris
