275
Issues importing Excel data to Ultrawingrid
hello Vince
We are using .Net 2009 Vol 1;
There are still some issues in Importing Excel data to Ultrawingrid
1) Cant import correctly if the data in header or cells are merged (dont know if this is a limitation)
2) Cant import data is correctly, if there are formulas in cells.
3) Not able to create "Header" in Wingrid with first row data of excel file..
I am using the code given in "excelio" as reference; I am not sure if you have any updated code available.
Looking forward to your earlier response...
  • 45049
    I recommend that you pursue these specific issues by submitting support requests, than through the forums, because it will likely take some in-depth research to determine what's happening.  Each of these is a separate issue, so each should be logged as a separate support request.  You should include the sample project you're working with in each support request, so that Developer support can better see what code you're using.
