I saw a similar question, but mine is the opposite. I want the user to be able to enter into the combobox
so I have my UltraCombo as DropDown. Here's my problem. I have a BeforeDropDown event inside which I go to the database and load a datatable. Than I bind that datatable to the UltraCombo datasource. As soon as the DropDown Box opens, the current value is blanked out. Even though the current value exists in the list that was loaded. Anyone else having these problems
This issue has been resolved in the latest service release as of 1/4/2012. You can download the Service Release from your My Keys & Downloads page: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
I have logged this as a development issue with an ID# of 96044. I will make another post once this issue has been resolved.
I will be happy to help you out with this issue.
I have created case # CAS-77063-KM3PFG for you to better assist you with this issue going forward. To access the case, simply log into your IG account and click on My Support Activity.
Please let me know if you have further questions in this matter utilizing the case created.
Oops, sorry about that. I misread the code.You are right, this does seem like a bug in that case.
I'm going to forward this thread over to Infragistics Developer Support so they can create a case for you and look into this issue more thoroughly.
Hi Mike, thanks for looking into this. I'm afraid, though, that it is a bug. What you're saying is correct if the combo was, in fact, using DropDownList style. But if you look at the sample, you'll notice that it's specifically set to DropDown style. So the value can be anything.
