1470
Editing decimal columns as integer
Hi there
I have UltraWinGrid with a bound column of type decimal.
We wish to treat the column as an integer with no spin.
If I set the format of the column to be say "###,###,##0" the format is OK
but if I set the InputMask of the column to say "nnn,nnn,nnn" it by default seems to apply the spin functionality to the columns cells and if I apply the format only with no mask then the first cell I click in displays the value to 4 decimal places.
If instead of using the format and inputmask I use the ColumnStyle = Integer then the column becomes non-editable!
My question is what is the appropriate technique for having both the display and edit mask of a decimal to be that of an Integer.
Thanks in advance
geoffhop
