3455
Display member and value member, for a textbox cell
In my application I have a cell which is TextBox style. This cell accept only numbers and if the user enter 0 (zero) the cell must show 'None' instead of zero for any other numeric values it must show the user entered value.
How can we implement this easily.
Ceaser
  • 469350
    Suggested Answer
    Hi Caesar,
    You could handle the KeyDown event of the grid to stop the user from entering anything but numeric characters.
    Another option would be to use a Mask, but it sounds like you don't want that.
    To translate 0 into "None", you could use a ValueList in the cell. But that might be a little weird, since it only needs one item in it. Unless you know all the possible numeric values the cell can accept. Is there a limited range of values, like 0 to 10? Or can it be any number?
    If it's limited, then I recommend the ValueList.
    If not, then your best bet is probably to use a DataFilter.
