Hello Experts
Please give me sample code to get Ultragrid's clicked row's cell value ?
Regards
Kyaw
You might have to use
Grid.DisplayLayout.Override.SelectTypeRow = SelectType.Single
Viswanth V.G
To disable rows multi-select do as follows:
grid.DisplayLayout.Override.SelectTypeCell = SelectType.None;grid.DisplayLayout.Override.SelectTypeCol = SelectType.None;grid.DisplayLayout.Override.SelectTypeRow = SelectType.None;
Thanks, Alex.
Hi Mike
By the way , let me know
(1) Can I make the gridview to allow only Single Row Selection ?
When the user clicks a row, it becomes the ActiveRow. So the easiest thing to do would be to check:
grid.ActiveRow.Cells["Key of the column"].Value
