Version 9.1
I'm using a ToolTip to display the full text of a trimmed UltraFormattedLinkLabel in a mock-up application I'm working on. I've used this code before on simpler forms, and it displays correctly. This form, which has a link label in a panel that's docked on the left via an UltraDockManager. In this case, as the attached picture shows, it's way off. Here's the code I'm using:
private void link_MouseHover( object sender, EventArgs e ) { var lbl = (UltraFormattedLinkLabel) sender; var ui = lbl.UIElement.GetDescendant( typeof( FormattedLinkEmbeddableUIElement ) ) as FormattedLinkEmbeddableUIElement; if( ui == null || ui.IsDataFullyVisible ) return; var tt = new ToolTip( lbl ) { DisplayStyle = ToolTipDisplayStyle.BalloonTip, ToolTipText = lbl.Value.ToString( ) }; var loc = this.PointToScreen( lbl.Location ); tt.Show( new Point( loc.X, loc.Y + lbl.Height ) ); }
Is there something I need to do differently here?
Thanks, that worked. For anyone who runs into this, here's the corrected code (at least for this circumstance):
private void link_MouseHover( object sender, EventArgs e ) { var lbl = (UltraFormattedLinkLabel) sender; var ui = lbl.UIElement.GetDescendant( typeof( FormattedLinkEmbeddableUIElement ) ) as FormattedLinkEmbeddableUIElement; if( ui == null || ui.IsDataFullyVisible ) return; var tt = new ToolTip( lbl ) { DisplayStyle = ToolTipDisplayStyle.BalloonTip, ToolTipText = lbl.Value.ToString( ) }; var loc = lbl.Parent.PointToScreen( lbl.Location ); tt.Show( new Point( loc.X, loc.Y ) ); }
Oh, misread that part. My test was also set too high if I used the DockableWindow (without adding the Height to the y-coordinate). If I used lbl.Parent.PointToScreen(lbl.Location) and used the result directly, the tooltip was displayed correctly:
var loc = lbl.Parent.PointToScreen(lbl.Location);tt.Show(new Point(loc.X, loc.Y));
-Matt
The screen shot in my last response shows it without the label's height being added to the y-coordinate, and it's still too high. Adding the y-coordinate is what I did on the simple form I copied it from, so the tool tip notification popped up below the control.
The x-coordinate that you're passing in is where the label begins, so I would think that it's correct that it's shown to the left of the 9; if you want it to be positioned farther to the right, you would have to adjust the x position accordingly.
I also just noticed something with your code that I hadn't noticed initially: you're adding the height of the label to the y-coordinate of the location you're showing the ToolTip. Without doing this, my initial suggestion of lbl.Parent.PointToScreen(lbl.Location) works.
Oops, yes I did. However, correcting that - and removing the adjustment for the label height - still didn't get it quite right (though it's at least back to being a stable location):
var loc = window.PointToScreen( lbl.Location ); tt.Show( loc );
With this, I would expect the tool tip point to be right above the "9" in "9/06/09 Network...".
