1960
Unexpected behavior of MinDate
I have an UltraDeteTimeEditor with MinDate = 01/01/2000 12:30 AM, MaxDate = 01/01/2000 11:59 PM and Value = 1/1/2000 12:31:00 AM. The spin button is set to visible. I'm attaching a test project with that configuration.
Try the following tests:
1) Run the app, select the minutes an click the down spin button. The control allows me to set the time to a value lower than 12:30 AM. I think that's a bug. The minimum should be 12:30 AM. When the control contains that value the down spin button should be disabled.
2) Stop the app, set the SpininCrement to 1 minute. Run the app, select minutes and click the down spin button. The value changes from 12:31 AM to 1:00 AM and the down spin button is disabled. That's not the expected behavior. I expect the same results described on test #1.
I'm I missing something?
Oscar.
UltraDateTimeEditorNumberSectionSelectionTest.zip
