90
Need help connecting SQL stored procedure to UltraChart
I am admittedly new to this, but after much reading I am stumped how to get the data from my stored procedure to appear on a scatter chart within UltraChart.
Here is what I am doing.  Just sample data I made up.  THE REAL DATA WILL COME FROM A STORED PROCEDURE.  If that makes a difference
Here is where I have created a sql datasource in Visual Studio and select the table above
Next I set the UltraChart datasource to be the Sql datasource above
Now it this point when i ran it it crashed.  Here is the message
Then I went in to the Chart Wizard and added a chart area and two axes.  Here I set the X-axis
Then set Y
And then at least when I ran it it did not crash, but no data was shown.  See below.
How do i connect my X data with the X-axis and Y-data with the Y-axis?  Can I do it in the wizard or do I have to do it in the code?
Please also keep in mind this is all just test data trying to get anything to work.  The actual data will be coming from a stored procedure whose output looks like this
TIA for your help.
