Is there any way to change the text of the ultraGridCell without changing its underlined value? i.e i want to change the cell.Text which should not change the cell.Value.
Thanks in advance,
Ujwal
Yes, you can do this with a ValueList. If you assign a ValueList to the associated column, that list is used to have the cell display one thing while its value is something else. For example, assuming the cell's value is 1, and you want to display "One", you might have a ValueList to which you add items in the following manner:
ValueList vl = new ValueList();vl.ValueListItems.Add( 1, "One" );vl.ValueListItems.Add( 2, "Two" );vl.ValueListItems.Add( 3, "Three" );
If you assign this ValueList instance to an UltraGridColumn, cells in that column whose value is 1, 2, or 3 will show "One", "Two" or "Three", respectively.
