195
Re-arranging columns
How can  I re-arrange my columns from code ? My grid is unbound and I am binding it on the fly using grid.datasource = mydatasourcetable. Here my data source table has columns in the order different than I want them on the grid. How can I re-arrange them?
thanks,
Yogesh
  • 918
    Suggested Answer
    In the initialize layout method I use the followng code to set up the columns.  This loops through all the columns in the grid and sets the values I want.  Use the visible position to set the column location.  Column numbering starts at 0.  Sometimes it take a bit of effort to get it just right.  I have had to skip a number and go to the next higher at times to make it order correctly.
    Dim aColumn As UltraGridColumn
    For Each aColumn In e.Layout.Bands(0).Columns
    Select Case aColumn.Key
    Case "Select"
    aColumn.Header.Caption =
    "Select"
    aColumn.Header.VisiblePosition = 0
    aColumn.Width = 59
    aColumn.DataType =
    GetType(Boolean)
    aColumn.AllowGroupBy = DefaultableBoolean.False
    aColumn.Header.Fixed =
    True
    Case "txtCompanyName"
    aColumn.Header.VisiblePosition = 1
    "Company Name"
    aColumn.CellAppearance.TextHAlign = HAlign.Left
    aColumn.Header.Appearance.TextHAlign = HAlign.Center
    aColumn.ExcludeFromColumnChooser = ExcludeFromColumnChooser.False
    'aColumn.DataType = GetType(String)
    Case"datInputDate"
    "Input date"
    aColumn.Header.VisiblePosition = 3
    aColumn.Width = 70
    Case"txtHomePhone"
    "Home Phone"
    aColumn.MaskInput =
    aColumn.MaskDataMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.Raw
    aColumn.MaskClipMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.IncludeBoth
    aColumn.MaskDisplayMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.IncludeBoth
    aColumn.Header.VisiblePosition = 12
    Case Else
    aColumn.Hidden =
    True
    aColumn.ExcludeFromColumnChooser = ExcludeFromColumnChooser.True
    End Select
    Next
