I have a form with several grids on it. One of the grids contains a column with a columnstyle = dropdown. If the user tries to enter data in to any of the grids and the above mentioned column is empty then I want to place focus on that column, enter edit mode, and force the dropdown to open for the user to select a value.
Here is what I am using so far:
ugGridHeader.Focus()ugGridHeader.Rows(0).Cells("KEYVALUE").Activate()ugGridHeader.PerformAction(UltraGridAction.ExitEditMode)
The real problem at this point is I don't know how to force the dropdown to open. Any ideas??
Thanks. Bill
Hi Bill,
I think you meant to use EnterEditMode, not ExitEditMode. But in any case, the action you really want is UltraGridAction.EnterEditModeAndDropdown.
