280
Add row in the main grid when TemplateAddRowonTop is enabled
Actually issue is that Grid works fine with all kind of paste operation correctly. I have grid with UltraGrid.DisplayLayout.Override.AllowAddNew = AllowAddNew.TemplateOnTop and when a user types in a field the new row is moved to the main grid with the row still showing IsAddRow = true. Similar when we change the row after supplying the values to the cells and move to the next row.
Now, I want the same scenario that when I paste the values into a cell that is in the Add Row (TemplateOnTop) using the Ctrl-V this does not move the new row to added row that it does not behave like behave the same as the above scenario does. I am here to get a way how to achieve this that when we paste data to the cell and grid move to the next row grid should add row to main grid from templateRow.
I am trying to find a way to make the grid behave the same way by forcing the grid to add the row like it does when the user types in the cell.
