I have created a ribbon bar in the designer and everything looks cool.
The only problem is -
when press Alt, the 1st button in QuickAccessToolbar area appears having default shortcut 1, the 2nd has shortcut 2.
I wonder if there's any way to disable the shortcut behavior on Ribbonbar.
I can see, in the designer, the ToolButton is not given a shortcut. Not sure why/how this *default* shortcut comes in.
I have enclosed a screenshot to help.
Thanks.
Jun
Hello Jun,
I believe that this topic has already been discussed in the following forum thread:
http://forums.infragistics.com/forums/t/31801.aspx.
Please do not hesitate to ask if something comes up.
