Well, im using an UltraComboEditor with checkbox items. When i have the list of items dropped, i change the checkboxes manually depends of the items that are checked, but i dont see that those items are checked/unchecked until i close and re-open the list, or just scroll down and up again. Seems like the control dont repaint himself when i change that property, but im not sure of that. ¿Any solution? (Tried to refresh / update, but nothing change).
This is a bit of the code:
private void cmbFamilia_SelectionChanged(object sender, EventArgs e) { // If the selected item is the first ("ALL"), i uncheck all other items on the list. if (this.cmbFamilia.SelectedItem == this.cmbFamilia.Items[0]) { foreach (ValueListItem item in this.cmbFamilia.Items) if (item != this.cmbFamilia.Items[0]) item.CheckState = CheckState.Unchecked; } else { Boolean ningunoChecked = true; // Else, if there is any item checked and is not the first, i must uncheck the first one. foreach (ValueListItem item in this.cmbFamilia.Items) { if (item.CheckState == CheckState.Checked && item != this.cmbFamilia.Items[0]) { ningunoChecked = false; this.cmbFamilia.Items[0].CheckState = CheckState.Unchecked; } } // If there is none checked, i must check the first. if (ningunoChecked) this.cmbFamilia.Items[0].CheckState = CheckState.Checked; } }
Since this bug was reported more than 9 years ago, I'm sure it's been long-since fixed. If you are experiencing some new or similar issue, please start a new thread and explain the issue and how to reproduce it and we will look into it.
Hi, can you update on the status of this bug?
Hi.
How do you solve your problem?
Ok, i submitted a support request, thanks for your attention.
That sounds like a bug; you might want to submit an incident to Developer Support.
